need to know part is located on vechile
Old 01-04-08, 08:13 AM
B
we need to know where the drive actuator is located on a 1999 chevy blazer sl 4.3 vortex 4wd
Old 01-04-08, 10:36 AM
carguyinva's Avatar
if you are referring to the 4WD actuator, it's located on the right front axle tube
Old 01-04-08, 05:59 PM
On the full size trucks, it is on the right axle tube. But on your Blazer, it is located under the battery tray. You need to remove the battery and the battery tray to get to it. Is is a vacuum operated actuator. I've seen alot of them fail due to battery acid leaking on them.
