97 ford contour problems
Received 0 Votes
i have a 97 ford contour,my turning signals have quit working also my hazzard, i want to change the flasher but i dont know where it is located,also my just stalls when i am driving it,not all the time but most. could someone please help.
Here's an Autozone link for you. It has everything you need for your turn signal/flasher problem.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
The stalling could be a lot of things. Getting a scan at Autozone would be a good place to start. That way you'd have a fault code to work with.
You may just need a tuneup or the EGR valve could be sticking.
This should get you started.
Hope this helps,
Bob
Hope this helps,
Bob
