96 dodge stratus
Received 0 Votes
hello all
i have a 96 dodge stratus 2.4 L 16v engine it stopped working one day, it cranks but it wont start can someone give me a clue what it could be and were to look, it had spark but wont start help please.
thanks
ELI
thanks
ELI
If you had spark, shoot a little starting fluid into the intake just past the air filter. If it starts then dies, you have a fuel delivery problem = filter, pump, regulator, injectors - that sort of thing.
If it doesn't fire at all, you'll need to confirm you still have spark. Pull a plug wire, fit a spark plug into it, ground the plug and have someone turn the motor over while you watch for spark at the end of the plug.
Post back with what you find.
Hope this helps,
Bob
Hope this helps,
Bob
