Headlights super bright only when I pull lever
Received 0 Votes
Do all vehicles do this? Is it running on both beams then, only? If so, why don't they have it do that then? I can actually see when that happens! I'd just LOVE to be able to see like that.
Try YOURS once and see what yours does.
Received 0 Votes
Who would be the most knowledgeable on this for a particular car? And is this something many people have done? Or is it more commonly done than people would think?
Received 0 Votes
Yup, flash to pass is what they call it. Most of the newer vehicles have this, but some still do not. But, at any rate, any vehicle can be wired to have both low and high beams on at the same time, while in high beam mode.
Received 0 Votes
With both going sustained and not for the split second that I refer to when I pull on the lever to go from low to high beam - will that be a problem with additional current flow with the way the headlights are fused?
I highly recomend everyone some night try YOUR vehicle to see if yours gets brighter in this way.
My '90 jeep cherokee also does that. Kind of handy when you need the extra light but I'd also worry about the extra current flow if it was kept in that position.
Received 0 Votes
Kits are out there, maybe not for your application though. But with a relay and some schematics, you could do it. Here is a link to the one for GM trucks,
http://www.google.com/url?q=http://w...S1C5rktwM0VzFg
http://www.stylintrucks.com/Articles...l/Article.aspx
Received 0 Votes
Thanks. I am going to look into this. I'm going to ask around. This is most interesting.
I just stumbled on this by accident, or rather happened to notice this one day recently, after all these years of driving, as to how the lights would get noticeably brighter just in that short while I click-held the light lever momentarily. What a huge difference in what you can see down the road.
Received 0 Votes
My 04 F-150 does the same thing, as did the 99 I had before. It's probably only vehicles with two headlight system where both headlights have two filaments, one for low beam, and one for high. We also have a Honda Odyssey with four lights, the outer two for low beam, then all four for high. It really lights up the road. One little idiosyncracy on my 99 F-150 that I discovered by accident was that if you pressed the cruise control ON button at the same time as the speed set button, the horn honked. The dealer could never explain that to me, but another used 98 that he had did the same thing. I was disappointed when my 04 didn't do it.
