Help me eliminate squeal
Received 0 Votes
Have a 77GM truck with inline 250-6 changed to standard head. When driving down road a squeal starts that gets worse with acceleration. Sometimes it stops. Power steering pump is new and belt is tight as stated by repair manual. Alternator is charging correctly and belt seems to have proper tension. If one can turn alt. pulley by hand(engine off)is is too loose? Could bearings in alternator be faulty? Have had some ps fluid drip onto alternator, could this provide squeak causation? What type capacitor would you recommend to alleviate alternator noise interfering with radio and limited cell phone use? Thanks for your time and help.
All is appreciated.
All is appreciated.
Received 0 Votes
You can buy filter caps for radio at most auto parts stores and probably at Radio Shack stores. Noise on the radio can also be caused by leaky or bad sparkplug cables and check grounds around the engine/frame/battery area.
I have also noticed that sometimes the alternator will emit noise to the radio when they are about to fail. I have had that happen to me a couple times.
Good luck with your project.
All is appreciated.
All is appreciated.
For the type noise you're describing, you should be able to get it by raising the hood and operating the throttle by hand. A piece of clean heater hose makes a good stethoscope to pinpoint where it's coming from. Just don't get it into any moving parts.
