2005 PT CRUISER Fog Lights
Received 0 Votes
I installed these foglights about 8 months ago, they worked fine, now they stopped working. Bulbs are good, I checked the wiring throughout, and i got power going into the switch itself, but still no lights, can the problem be in the Headlight Relay that is connected to the fuse box, headlights and everything else is working, thanks
Received 0 Votes
You might check to see if the sockets have good grounds and also take a voltage reading at the bulb sockets from a good ground to the hot side of bulb socket. If you dont read anything there then follow your wiring back to the switch.
