1992 Honda Civic won't start
Received 0 Votes
Received 0 Votes
It is very likely that the contacts in the ignition switch are worn out. This is somewhat common on older Honda's. The electrical part of the ignition switch can be replaced separate from the ignition lock cylinder so you will not need a new ignition key. Not a difficult job to replace either but it is hard on the back.
