Gasket sealers do's and donts.
Received 0 Votes
Ok i might pull the throttle body off my toyota celica. The reason being is the IACV more than likely needs cleaning and or replaced. The 1st question is do i use a gasket sealer when installing the throttle body and the IACV? I know the throttle bodys gasket is diff and the IACV uses some sort of rubber gasket. 2nd question is the use of a torque wrench. Is it absoltely neccasary to use? Thanks for all info.
Skip the sealants; the gasket does the work. If you need to hold a gasket in place for assembly a slight amount of an adhesive can help (my choice is 3M trim contact cement), but forget troweling on the RTV.
Absolutely necessary? No. Desireable when possible? Yes. I just had to fix a bad injector yesterday on a project car ('96 Corsica, 3.1L; picture here: http://forum.doityourself.com/showthread.php?t=331955 ) that involved removing the intake plenum and some attaching parts. Didn't pull out my torque wrench and I'm not concerned. In theory every single nut and bolt has a torque value; in practice many that are not torque-critical are installed without a torque wrench. When you start talking things like cylinder heads and such, now we're talking critical.
Received 0 Votes
The screws holding the IAC to the body will be corroded.
Give 'em a blast of PB to loosen 'em or you'll have an interesting time if a head(s) shear off.
If the slots give way, go at 'em with a needle-nose vise-grip.
I replaced the phillips heads with SS hex heads - cheap, and easy to screw in.
I didn't torque 'em but snugged 'em up firmly.
