ford fuel injectors
Received 0 Votes
ford fuel injectors
Have taken off the fuel injectors from a ford 4.0 doing work on the engine,would like to if there is a way to test each injector off the car maybe with a multimeter or some other gauge to see if there in good shape Thanks
You can check resistance across the terminals; should be about 12-15 ohms, not sure exactly what yours would be. I just got done working on a Chevy and they were 12.7-12.8. Check them all and they'll all probably all fall within a couple of tenths of each other. A big difference would signal a questionable one.
