2000 Astrovan headlight problem
Received 0 Votes
Wife's van with DRL lights. Headlights stopped coming on, all other running lights OK. Checked fuses underhood, they OK. I assume the headlight relay in the under the hood fuse box is malfunctioned. Is this something I can easily replace and what else might cause the malfunction.
Thanks,
Oldgolfer
Thanks,
Oldgolfer
Thanks,
Oldgolfer
Thanks,
Oldgolfer
Received 0 Votes
I assume that the relay in the under hood panel can just be replaced by plugging in another.
The lights probably went out one at a time. The problem is that most people don't notice one but when the second one goes - wow it's dark out.
Use the KISS principle - keep it simple sir. Replace one bulb and if that side lights then replace the other side.
