89 Delta 88 fuel line replacement
Old 01-26-08, 08:29 PM
Unhappy 89 Delta 88 fuel line replacement
I need to replace a leaky fuel line on my 1989 Olds Delta 88. I can't seam to find the relay to disconnect the fuel pump so I can relieve the pressure before removing the old one. It is not located on the firewall nor is there a fuse inside in the fuse block. Can anyone tell me where I might look for the relay?
Thanks, TULLARZ
Old 01-27-08, 05:27 PM
See if there is a small red plastic box with a flip top on the fender well under the hood. If so, open it and you will find both the fuse and the relay.
