1995 ford ranger timing belt replacment
Received 0 Votes
See if the instructions here help:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Not the best diagrams I've seen, so not sure if it will be any help.
If you have a distributor, you can remove the cap and watch the rotor as you rotate the engine; watch for the rotor to point towards where the #1 plug wire would be and align the TDC mark on the crank pulley. For distributorless you can either watch the valves move and when you see the #1 intake open and close align the tdc mark when it get's to the pointer OR you can pull the #1 spark plug and slowly rotate the engine with your thumb over the plug hole; when you feel compression, align the marks wehn they line up. Do NOT do this by bumping with the starter.
