Auto Radio: Connect Datsun Hitachi KMS - 3601 B
Old 02-03-08, 12:14 PM
F
I would like to hook-up a radio (Model Datsun Hitachi KMS -3601 B), but I cannot find info about the color code of the many wires coming out of the set. There is also a mysterious socket at the rear of the set.
One group of wires has:
a black wire (ground?)
a red wire with white stripe (+ 12 volts?)
a green w. yellow stripe (lighting or power antenna??)
a blue wire
The speaker wires are as below. Which are left and right, plus and minus?
light green / blue stripe & lt.green w. white stripe
yellow with red stripe & yellow w. black stripe
white with black stripe & white w. no colored stripe
dark blue w. black stripe & dark blue with red stripe
Some helpful pointers would be much appreciated
Old 02-03-08, 02:49 PM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Well, as to the speaker wires, + & - don't make a whole lot of difference and once you get it powered up you should be able to figure out what speaker is what by adjusting balance & fade.
Don't know if it's standard, but I think most power antenna leads I've seen are blue. Red and black wires could definitely be the + & -. The other lead, green w/yellow could be the second hot lead. Radios have two hot leads, one switched and one always hot (to maintain settings when you turn the key off).
I assume there's no diagram on the side of the radio? You might try removing the top or bottom panel on the radio body to see if there's a diagram on the underside.
Only probelm with guesswork is you can accidently fry the unit by an incorrect connection.
Found these guys while trying to find any info for you:
http://www.justradios.com/
Old 02-11-08, 10:04 PM
F
Thank you tow_guy re Datsun Hitachi radio.
Thank you tow_guy for taking the time to answer my question and even snoop around a bit for me. There is no diagram outside or inside. Not much luck on-line. But I think it would be safe to go with 12v + to the red/white stripe, black ground, and blue for message to antenna motor. I forgot to mention a solid green wire along with the non spkr. wires. I do enjoy getting to work some old thing that I have salvaged & saved for eons.... With kind regards, fixoldstuff.
