93 Ford Aerostar won't start when it rains. HELP!
My van won't start only when it's rained. This must be a common problem because I have seen this same problem in Fords, posted on other sites which require payment to see the answer. Can anyone out there help me?
Please?
Old post but ....They are bad for drawing moisture. On a dry day, after you've had it started and everything is dry spray the entire ignition system with ignition sealer. You can get it from any auto parts store. That usually takes care of it.
