2003 Honda CRV wont start
Received 0 Votes
My Battery is OK, but I have not electrical anyplace. Was working perfect and car was in the garage so when I went to start it this morning everything was dead.
thanks for your help
Harlan
Harlan
Received 0 Votes
Harlan,
No insult intended but how do you know your battery is "ok"? Should be over 12.5 v at rest. Have you checked cables at battery and starter for corrosion? All fuses ok? Any anti-theft systems that might be acting up?
Received 0 Votes
I used a volt meter on the battery and it's about 14v. no corrision. Just checked again and everthing is dead as I tried to used the auto lock and that didn't work. I'm not sure where to begin with anti theft. Also did not check all of the fuses. Should there be one that would shut off everything?
Harlan
Harlan
start by checking the fuses under the hood...the big ones...and yes, the main fuses can cause everything to be dead. 14 volts on the battery? open circuit voltage on a fully charged battery is 12.66 with no surface charge. also, just because the connection don't have green/blue corrosion on them doesn't mean that they are good. they ought to be removed and cleaned with a wire brush to eliminate them for sure. unless you are familiar with voltage drop testing, just clean em.
sounds like a fuseable link to me! look around the battery pos. cable for a large wire, maybe with an enlarged portion and see if it is blackened/soft? i'm and old car kind of guy; not REAL adept at the newer cars. i did have that problem on a nissan once though. just a thought!
mike...
you don't find fusible links on many asian cars, if at all any more, they use large fuses...up to 80A on some applications. the main fuses protect the power distribution chain beginning near the battery
Received 0 Votes
If memory serves me correctly I believe some CRV models had problems with the ignition switch. Some were even covered under a recall. A faulty ignition switch could cause this. A blown main fuse could cause this. Or a problem with the positive or negative battery cable.
