1986 toyota camry
Old 02-04-08, 09:40 PM
C
1986 toyota camry
Engine wont intake fuel and dies while driving on freeway at a stop light or going 35 down the road.....runs great in nuetral...thinking it might be a fuel filter. Need suggestions or ideas....maybe injectors,carborator not sure if it would be cheaper to get a new car
any help much appreciated
Old 02-05-08, 04:31 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
If it's a carbureted engine could be either fuel filter or carburetor float; more likely the filter. Most older Toys have a sight glass in the side of the carb. Next time it dies, pull over and check the sight glass; you'll probably see the fuel level well below normal or maybe not at all. Proper level will be right in the center of the sightglass.
Old 02-05-08, 06:22 AM
C
fuel filter
can you tell me what the sight glass looks like on carb and also where is the fuel filter located and can I change it myself
thanks again
