96 Contour blower motor fuse
Old 02-06-08, 09:43 AM
1996 Ford Contour, 4 cyl, auto. Everytime we replace the fuse for the blower motor (for the heater) the fuse blows within seconds - even with the blower motor turned off. You can hear the blower motor start to spin if you try this with it on. Any suggestions?
Old 02-06-08, 12:47 PM
the_tow_guy's Avatar
I would suspect either the motor is shorted interanlly or you have a short somewhere between the switch and the motor. Going to take some work with a multimeter to track it down. Also a wiring schematic like here:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 02-06-08, 02:31 PM
carguyinva's Avatar
disconnect the blower motor and try another fuse...if the fuse blows, it's a short to ground elsewhere in the blower control circuit. if the fuse does NOT blow, the motor itself is bad.
if the short is somewhere else...it's not a good DIY project
