88 Chevy Corsica - turn signal problems
Old 02-11-08, 03:31 PM
A
1988 Corsica for some reason the right turn signal doesn't work. I have replaced all the bulbs in the cluster of the right-rear turn signal and the flasher unit has been replaced. The brakes work and the hazard lights work...any ideas what to check next?
Old 02-11-08, 04:01 PM
HotxxxxxxxOKC's Avatar
Have you replaced the front bulbs as well?
Do the blinkers come on, but do not pulsate?
If they do not come on at all, I would suspect faulty wiring, usually corroded wires at the light assembly.
Old 02-12-08, 08:16 AM
A
The front blinkers and left rear come on and work just fine, it's only the right rear signal. They show to work from the driver's seat...It's just looking at the rear of the car, the signal doesn't light up.
Old 02-12-08, 01:07 PM
mikeTN's Avatar
Question
if you have a voltmeter, pull the bulb, turn on the turn signal in question and check the wire for voltage.sounds like a bad wire or corroded terminal, if the bulb is good.
Old 02-13-08, 06:24 PM
A
Thanks Mike..I haven't had a chance to get a voltmeter, but I will pick one up tomorrow. I'll let you know if it works.
Old 01-21-10, 10:16 AM
T
Cool turn signal problem in my 88 chevy corsica
my blinkers are not coming on when i go to turn..no signal no sound, but every now and then they will come on while im in the middle of turning...( i still TRY to use them) they only work when the want to!
any ideas..i was thinking wiring or relay untill they started coming on again. we are buying a manual tomarrow. but an opinion may be helpful too!
Old 01-21-10, 10:42 AM
B
Cleaning electrical connections is a big help!
Remove the bulbs, clean the connections, then squirt a bit of "dielectric grease" on the contacts.
Has there been any trailer towing wiring added?
If there are electrical connectors under the rear of the vehicle for the rear lights, disconnect them, clean with electrical contact cleaner, squirt a bit of dielectric grease on, then reconnect.
I'm afraid that the above probably will not do any good, but sometimes this is the problem and these things are easy to do.
Also be sure you have the correct factory specification bulbs installed.
Other than that, sounds to me like it would very likely be the turn signal switch. These can be a royal pain to replace. And you would need a factory service manual set for instructions on how to do this. And special tools are usually required.
Might want to take it to a mechanic if you are not experienced at this sort of thing.
Old 01-21-10, 11:01 AM
E
What about the 4-ways working? That might help you isolate it down to a quick repair around the signal relay.
