Locked up
Locked up
THANK'S ART:
I believe there is a little connecting rod or cable that attaches in the column that releases the shift lock. Did you forget to connect this?
To add:
Does your steering wheel unlock?
To add:
Thanks Art
Does your vehicle have some sort of brake pedal release? Do you remember how it used to behave when it worked? Did you have to put your foot on the brake first to disengage?
