98 ford exp
Received 0 Votes
98 ford exp
i have a 98 ford exp and it will not start. i was leaving the gas station and it just died on me. i tried to start it later that night i started for a few sec with my foot on the gas all the way and it sounded like crap then died. i tried to start it one more time and no go. but if i let it sit for a few hours it will start up sound like crap and die. I thought it might be bad gas but i drained it and put new gas. New fuel filter new spark plugs and it did not help. Can any one help me thanks
Received 0 Votes
When you cycle the key to "on" position,(not start) do you hear a buzz or humming noise from the rear area of the vehicle? (Fuel pump ) A quick swat to bottom of fuel tank, with a rubber mallet/hammer may tell you. If it starts after the hit, fuel pump is on it's way out/gone.
Couldn't hurt, but there are a lot of things that will not necessarily show up in a code, like low fuel pressure output from the pump, or failing electronic ignition components.
Received 0 Votes
Basics: Check for spark.
Check to see if starting fluid gets it to start better than how it starts when it is NOT starting right.
Check engine timing. Often the engine runs good right on up 'til engine is shut off. Then upon the next "start", it jumps teeth or even strips out about 5 teeth out of the serpentine belt.
