1998 Dodge 2500 Door Latch
Received 0 Votes
I was wondering if any one might have or know where I might be able to get a inside door latch for drivers side front door quad cab because mine is wore out and it wont shut tight any more. I have looked all over the Internet and could not find a single thing, or even if someone might have a part number that might help me narrow my search down.
Thanks a lot ahead of time for any help
Randy
Randy
You might try adjusting the door striker in a little, After a few years the door seals flatten out and causes a loose rattly door.
Also spraying some type lube on all the hinges and latch assemblies may help.
If that doesn't work, have you ever heard of www.uneedapart.com? You can mention any parts you might need, and junkyards across the country will email you if they have the part. Good luck
