bypass ignition switch
Received 0 Votes
How do you bypass ignition switch. I am not sure what terminals on starter to jumper. I want to see if starter will engage or if there is problem with switch
Received 0 Votes
I don't know what kind of car you have but if you can remove the starter, most auto parts stores will test the starter for you for free. Watch how they connect the wires to the starter. I always seem to have trouble with the starter relay on my old bronco. Replacing this relay has solved my starting problems in the past.
Bob H
Bob H
Received 0 Votes
I didn't realize VW was that fancy in 85. They might be right but I would try several stores. Call around. Are there any in line fuses in the starting system? Good luck.
Bob H
Bob H
