2003 Neon transmission problem
Old 03-10-08, 03:15 AM
i have a 2003 dodge neon (automatic) and this morning on my way to work it started jumping out of gear and finally would not go into gear at all.* When it finally did, i only had first gear and it started making a distnict whining noise.* What could this be?
Old 03-10-08, 04:01 PM
how many miles on car? have you checked trans fluid level?
Old 03-11-08, 11:36 AM
carguyinva's Avatar
noises are almost always bad in an automatic. whining coule be low on fluid, called pump cavitation...or there could be small particle contamination from a gazillion places. a tear down is normally required to find the smoking gun...unless it's a pattern failure. an experienced trans tech may know right away by your description.
