95 K2500 Transmission shift problems
how many miles? sounds like some band adj. is in order. have you ever changed the fluid and filter(if it has one)? if you have a service manual, see if the bands are adjustable from the outside. some(dodge) are partially adjustable from the outside, and the rest is adjustable with the pan off. i'm guessing a lot of miles and no trans. oil change! good luck.
it doesn't have any band adjustments. it works ok when you drive it easily because it can't take the heavy load. when you mat the accelerator, you are exceeding it's ability to hold (it slips)...when it slips, it puts the trans into a failsafe mode and then it just stays in one gear. that trans is toast if it slips at all...there are no adjustments and at this point, changing the fluid will most likely hasten it's complete demise. your options are, baby the hell out of it and get all you can...or drive the hell out of it and risk walking. good luck...
