2001 chevy silverado 5.3 problem
Old 03-11-08, 06:42 PM
T
got check engine light on, says vacuum leak small leak, any common problems as to where to start to look ??
Old 03-11-08, 08:03 PM
There is a service bulletin out for the intake gaskets leaking. That would be my first place to look.
Old 03-12-08, 02:24 PM
T
I used to have one of those and I got the code. Turned out it was my gas cap. The seal was going bad.
Old 03-12-08, 05:37 PM
T
thanks
I will look at both, thanks, where might I find info on the bulletin?
Old 03-12-08, 07:33 PM
The dealership.
Old 03-18-08, 07:42 PM
mikeTN's Avatar
Received 1 Upvote on 1 Post
EVERYWHERE there is vacuum present. tug on all hoses lightly. if they come off, they are too loose. cut of 1/8 inch and re install or replace..then go to the expensive stuff.
