99' Chevy transmission
Received 0 Votes
Hi, I'm James and I have a small problem. I have a 99' Chevy Malibu and I wanted to check my transmission fluid, but my car does not have a stick. How do I check it? And... If I check it and I need fluid how do I know how much to add? In other words, How do I know when to stop pouring?
Thanks, James
Thanks, James
There are several makes/models that no longer have a dipstick. Guess the engineers decided they'll never leak. As far as I know, the way to check/fill is the same as if you were doing the rear end on a rear wheel drive. Locate the filler plug and add fluid until it comes out the hole. Personally I prefer a dipstick & tube.
Received 0 Votes
Thanks, James
Thanks, James
Remove the transmission plug.
Important
The transmission fluid may darken with normal use and does not always indicate contamination or oxidation.
Transmission fluid (At least 104°F) 5-10 minutes at idle will give correct temp.
Does the fluid have a burnt odor or a dark brown color?Check the fluid level. The fluid level should be even with the bottom of the threaded plug hole.Is the fluid level low?
Add DEXRON® III automatic transmission fluid in increments of 0.5L until the fluid drains from the plug hole.
Install plug before stopping engine or fluid will spill out of plug hole.
Pan drop and filter change 7.5 qts
Check plug is just to the right of the passenger side axle housing , 11 mm plug, can't miss it, only one there.
Hoist is optional, just needs to be level and plug accessible.
Check plug location.
http://i45.photobucket.com/albums/f9...G_0624_1_1.jpg
Received 0 Votes
On BMW's, at least the M3's...no dipstick. But it still isn't that hard to change the fluid. But with BMW's they claim their tranny fluid is good for life, so you shouldn't have to check, and with the newer Beemers, BMW does the service anyway.
As for the bean counter, I don't think it was a cost cutting measure as much as a money maker. If you can't do it, the stealership has to and their prices are expensive.
the factory doesn't make anything on service and could really give a rats ass about dealer techs...it's a bout cost cutting. if they can cut a foot of wire out of a car to save pennies during production, they do it. just multiply the number of stickless units by units sold and you see what i mean
Received 0 Votes
So Sorry but you are wrong! I have many GM published articles on DEXRON VI and none of them says anything about the VI standing for Viscosity Improver. It stands for 6 in Roman Numerals only. I'm courious, what do you think the III in DEXRON III stands for? I have copied one of the GM DEXRON VI articles below.
In early 2005, General Motors released a newly developed automatic transmission fluid (ATF) for the factory fill of all GM Powertrain stepped-gear automatic transmissions. The new fluid provides significantly improved performance in terms of friction durability, viscosity stability, aeration and foam control and oxidation resistance. In addition, the fluid has the potential to enable improved fuel economy and extended drain intervals. Because the performance of the new fluid far exceeded that of the DEXRON-III service-fill fluids available at the time, it became necessary to upgrade the DEXRON service-fill specification in order to ensure that similar fluids were available in the market for service situations. This latest upgrade to the service- fill specification is designated DEXRON-VI (fig. 1).
Since General Motors introduced the first ATF service-fill specification in 1949, it has been necessary to upgrade the specification periodically.
The upgrading process ensures that available service-fill fluids are of an appropriate quality for use in transmissions that have been designed around the factory-fill fluid performance.
TIP: As with previous upgrades, DEXRON-VI fluids are designed to be backward compatible with earlier transmission hardware. More importantly, earlier type fluids are not forward compatible with transmission hardware that was designed to use DEXRON-VI fluid.
DEXRON-III is not compatible with the most recently designed transmissions, and the use of these earlier type fluids could result in transmission damage. All current calibrations and certification tests are now conducted with DEXRON-VI ATF. DEXRON-III fluids should not be used for those applications where the owner manual recommends the use of DEXRON-VI.
TIP: GM does not license or support obsolete ATF specifications or the use of fluids that are being marketed against cancelled specifications.
All DEXRON-III licenses expired at the end of 2006 and will not be renewed. Beyond that date, GM will support only DEXRON-VI fluids for use in Hydra-Matic transmissions. Avoid fluids sold in the market after that date bearing claims such as “suitable for use in
DEXRON-III applications” or similar wording. DEXRON-VI licensed fluids are fully backward compatible and can be used in all applications covered by earlier GM ATF specifications.
The use of unlicensed fluids and/or non-GM approved aftermarket additives may prove detrimental to transmission performance and void warranty coverage.
- Thanks to ------------ name removed
Precaution: DEXRON-VI in Manual Transmissions
When DEXRON-III is indicated as the fluid fill for manual transmissions and transfer cases, DO NOT use DEXRON-VI. Instead, use GM Manual Transmission Fluid p/n 88861800 in these components.
TIP: Refer to PIP3836B (Feb. 2007).
If the manual transmission or transfer case indicates use of DEXRON-VI, then, of course, it should be used.
Purging Equipment
Before filling your bulk fluid equipment with DEXRON-VI, be sure to purge the old oil from it.
Also, be sure to purge your J-45096 Transflow machine before using it with DEXRON-VI.
Purging Equipment
my .02 worth...i've seen the chemical and performance data on Dex VI and it outperforms Dex III by leaps and bounds. widespread use will have a very noticeable effect on automatic trans longevity and driveability.
Received 0 Votes
Here's some more info from GM on DEXRON VI.
Dexron VI During the first six months of 2005, GM Powertrain will transition from Dexron III Automatic Transmission Fluid to Dexron VI.
Dexron VI offers the following longer-life characteristics:
Extended factory fill for life
150K miles for cars
200K miles for trucks
Clutch friction stability
Improved 100%
Clutch durability due to fluid
Improved 120%
Oil film thickness
Increased 20%
Fluid oxidation
Improved 100%
Foam / aeration
Improved 150%
Shear stability
Improved 200%
TIP: Dexron III and Dexron VI can be mixed with no problem.
- Thanks to ---------- name removed
150K miles for cars
Improved 100%
Improved 120%
Oil film thickness
Increased 20%
Fluid oxidation
Improved 100%
Foam / aeration
Improved 150%
Shear stability
Improved 200%
Received 0 Votes
Purging Equipment
Purging Equipment
Well if Dexron 11 and Dexron 111 are roman numerals what happened to IV and V, GM as always went in sequence.
and even more confusing...where does Dexron III (G) and Dexron III (H) fit in...and for the burning question of the day...
why do so many folks call it "Dextron"...alas, perhaps it's a southern thing...er, I mean...thang!
