shakes when brakeing
Old 03-17-08, 03:07 PM
F
Received 1 Upvote on 1 Post
91 olds cutlass ciera
when i apply the breaks while driving the car shakes pretty badly once i release the brakes its fine. would i be correct in thinking its the brake routers or is there something else.
Old 03-17-08, 03:34 PM
C
You would be correct. Have your rotors checked or just replace if the price is reasonable. Suspension (tie rods, ball joints, etc) can also play a role, but the most likely cause are the rotors.
Old 03-17-08, 08:27 PM
zachh1020's Avatar
Yep. had the same problem here. Warped rotors.
Old 03-18-08, 03:22 AM
more info
Buy good quality parts made in America or Canada and use a torque wrench to tighten wheel nuts.
Old 03-18-08, 03:24 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
And after you get the rotors changed, avoid running through standing water after a hard braking. It will tend to warp even new rotors.
Old 03-18-08, 07:06 PM
mikeTN's Avatar
Cool
if you do run through standing water, apply SLIGHT brake pressure while going through and a couple of car lengths afterwards to keep the rotors from cooling too quick.
