Car Leak
Old 03-19-08, 05:05 PM
A
Car Leak
We have a bad car leak. We had the front window siliconed so rain couldn't get in. But it's not the front window.
The driver's side floor gets sopping wet whenever it rains.
Any ideas?
Old 03-19-08, 07:21 PM
mikeTN's Avatar
Received 1 Upvote on 1 Post
Question
i'm guessing, but it gets wet SITTING? how old is the car? does it have an antenna on the drivers side? look under/through the grill(if there is one) on front of the windshield for signs of rust or a seam that is not sealed. most leaks i see are from the windshield, usually at the bottom corner. the windshield, by the way, needs rubber around it not silicone.
Old 03-20-08, 04:21 AM
rshack's Avatar
I had a same problem last year, found out the drain holes just below windsheild wipers plugged with small tree buds, from parking under tree. Removed long plastic molding btwn
windsheild wipers & hood and clear debris.
Hope this works for ya,,,
good luck!
Old 03-22-08, 04:06 AM
K
leak
what year, model ?doors. can you see the water dripping .
