1990 Astro Van Speaker removal?
Old 03-20-08, 07:25 PM
H
Can someone please link me on where I can find instructions(or tell me themselves) on how to remove the front speakers for a 90' astrovan? I know it involves taking the door panel off, just wanted to have something to read up on.
-Taylin
Old 03-21-08, 05:30 AM
the_tow_guy's Avatar
Received 134 Votes on 104 Posts
That's going to be tough to find; even most repair manuals are pretty thin on topics like door panels. Generally you will need to remove any screws that are visible and/or that hold on things like armrests. Depending on the lock & window configuration you will either need to remove the handles or pop off the control panel and disconnect wiring. Then the panel itself is popped off the push-in fasteners around the perimeter by either prying with a wide-bladed tool or you can use the special pliers made for the job. With the panel off the speaker should be visible and will probably be held on with 4 sheet metal screws.
