alternator no charging
Received 0 Votes
my alternator is no charging a replace for a new one and is no charging i replace it because when i drive my car is fine but when i slow down or stop it look like i want to stop and start shaking some tollme that was the alternator,or the air valve,or the gasoline filter any one know
Received 0 Votes
So you replaced the alternator only on a hunch?
Your rpm's are low at idle? Is that it? And less than what it used to be? Does the engine run smoothly at rpm's just barely above idle speed, or not?
