2000 dodge neon
Old 03-27-08, 05:51 PM
2000 dodge neon
i have a 2000 dodge neon that the a/c fluid is blowing out of the expansion valve and it will not keep the pressure or fluid . i have to disconnect the wire harness to keep it from making a mess. is my a/c pump bad? or is there something else i should check?
Old 03-28-08, 07:01 AM
the_tow_guy's Avatar
Refrigerant is leaking externally from the expansion valve? The expansion valve would have to be bad unless one of the lines is leaking.
