87 camaro tranny pan trouble-700R
Received 0 Votes
Thanks!
Lisa
DO NOT use a larger tool. get a tap the appropriate size(maybe 5/16 SAE) and re-tap the hole. take a bolt if you need to buy a tap. the center bolt is the trans. mounting bolt. what ever you do, do NOT overtighten the pan bolts or it will leak FOREVER! check the teflon washer on the drain plug if it has one. TAKE TWO DEEP BREATHS AND RELAX. PICK UP TOOLS! if you aren't making mistakes, you are not doing anything!! LUCK!
If the center mount bolt wont come off, there are two 15MM bolts holding the top of the mount to the trans "TAIL" . You may remove these as an alternative, Although They arent as "EASILY ACCESSIBLE".
The pan bolt hole should be "Re Tapped"and the bolt carefully installed. Dont force it,if you crack the aluminum, it will leak miserably.
i think that one way or the other, the best repair is going to be to gain access to the cross threaded bolt hole by getting the cross member or mount out of the way. I've never seen a mount to bracket nut that wouldn't break loose on a GM vehicle (and I've had a thousand trannys out of them...just ask my aching and arthritic right elbow!). if he's using a short ratchet, switch to a lnger handle or even half inch drive. most of the time, once aluminum has been cross threaded, running a tap into the hole just removes more materiel and then it won't hold the proper torque. the best and permanent fix is to install a thread insert. the kit is a bit pricey but he repair is better than original and it won't ever be a problem again...provided that he doesn't try to cheat the bolt hole again! been there, done that....it's how i know about thread inserts. the directions are simple to follow...right on the package. and...it's a metric thread...definately NOT 5/16".8mm X 1.25mm thread pitch, most all parts store carry insert kits.
Received 0 Votes
My hubby was way to angry, so he just stepped back.I really like the idea of going to an after market pan with a drain plug. I couldn't believe it didn't have onme. They're just going to retap it, which my husband could have done..........had he not wanted to BURN it in the driveway. I guess all you guys know what I mean! Thanks sooo much!!
