96 Nissan Maxima power steering belt
Old 03-30-08, 12:38 PM
(1996 Nissan Maxima 3.0L) How in the heck do you get the belt that goes onto the power steering pump on? Can get the pulley to loosen to get the sucker on. The old one broke btw.
Old 03-30-08, 01:59 PM
mikeTN's Avatar
Received 1 Upvote on 1 Post
Smile
had an old maxima(85) and had to remove the right front fender inerliner(v-6) to do anything to the front of the engine. hope this helps.
Old 03-30-08, 03:09 PM
W
Has to be done from the bottom.........remove right side splash guard and you'll see a 12 mm adjustment bolt and a long 12 mm that will move the pump up and down.........The forward belt is a 14 mm nut and a 14mm adjustr that you access from inside the engine compartment............just did one yesterday
