Oil leak
Received 0 Votes
Oil leak
I have a 1999 Ford Expedition that has an oil leak above the filter, is this coming from the oil pump seal?
Received 0 Votes
The oil filter screws to a housing that bolts to the engine block........Those gaskets leak like a pig........Some Expeditions also have a remote oil cooler and the "O" ring on the cooler goes bad as well.........The "O" ring, naturally, is not available seperately........making you buy the entire cooler. I'm told you can replace th O ring with one from a filter.........tried that twice with no luck
Possibly, but let me check other possibilities in the morning when i get in to the shop.I have a 99 and will check for other possibilities.when you say oil pump seal are you refering to the front crank seal, if so, no not a hard repair.
I am not sure how the Oil Pump got involved since it is mounted on the front internal, but the oil cooler removal for 4x2 is
Drain the engine cooling system.
Remove the drain plug and drain the engine oil.
Remove the oil bypass filter (6714).
Disconnect the coolant hoses from oil cooler (7A031).
Remove the insert and remove the oil cooler.
Clean and inspect the sealing surfaces.
Installation
To install, follow the removal procedure in reverse order.
For the Oil Adapter
Remove the left engine mount.
Disconnect the oil pressure sender electrical connector.
Disconnect the lower radiator hose (8286) from the oil filter adapter.
Remove the bolts and the oil filter adapter (6881).
Installation
Installation
For the Oil Adapter
Installation
