98 lumina 3.1L sputters want start
Old 03-30-08, 02:55 PM
A
98 Lumina 3.1L want start. For about 3 days I cranked my car and it would run fine for about 1 minute. Then it would sputter and finally cut off. After a few more time of cranking it went back to normal. Now it only sputters and want run.
We had the codes read and the tech said they were the egr valve and mass air flow sensor. The egr valve was cleaned and the air flow sensor replaced. The problem still continues.
Old 03-30-08, 03:11 PM
mlass's Avatar
I would look at the Catalytic Convertor.
20yeartec's Avatar
check fuel pressure? possible bad fuel pump.
Old 05-06-08, 03:24 PM
A
Problem fixed, was the fuel filter. Thanks for the input.
