1995 Mercury Mystique Overdrive
Just changed engines in my sons car but now for some reason overdrive and cruise don't work They both worked fine with old engine so I figer we did something wrong when we switched engines Any ideas??? 1995 Mercury Mystique 2.5 auto
being a'95, i'm sure they are electrically controlled. i would look at fuses first. then all the elect. connections you un-plugged to replace the engine. check the plugs themselves to see if they are plugged up snugly.
