cavalier heater switch
Old 04-03-08, 03:35 PM
Can any one tell me if it is a diy job to replace a fan speed switch? It is on a 2002 cavalier 2.2 and the fan works on the two high speeds but will not run on two low speeds. Thanks for any help.
Old 04-03-08, 03:42 PM
HotxxxxxxxOKC's Avatar
Sounds more like the resistor pack then the control switch. Resistor pack is usually mount around the fan casing.
Old 04-03-08, 04:51 PM
Unclediezel's Avatar
Agreed..........................
Old 04-04-08, 07:44 AM
not switch
I concur I would check the resistor they go out and control your fan speed.
Old 04-04-08, 02:49 PM
Smile
I have 2001 Sunfire, I posted about the same problem a few weeks ago and the guys here were right, it was the resistor, it had burnt out sections on it - cost about ($35 cdn new) mine works on all 4 speeds now, quite a common problem from what I hear, it took about an hr to put in. Mine looked like a big computer chip, comes with plug, you just plug it in.
