96 dodge caravan heater fan dosen't work
Received 0 Votes
96 dodge caravan heater fan dosen't work i've changed the dash control panel the coil thing in the firewall the relay under the dash and in engine compartment though not at the same time i used a new one to swap out what else can i do ?
the two obvious things are the fuse and a bad blower motor. i'd say if those 2 things check out ok, then some systematic diagnostics are in order. apply power and ground right from the battery to the blower motor and see it it works...check the fuse. post back and let us know what you find...
