Similar problem.
Similar problem.
Just bought an 02 Sentra with front end knock at low speeds over small bumps. I replaced the struts, stabilizer links, front motor mount and sway bar bushings. It's a bit better but still knocks over cracks in the road etc., but only at very low speed.
Any ideas ?
Any ideas ?
hearandnow...i moved your post so as to avoid confusion. thanks for posting...
sounds like you've already replaced quite a few parts...i'd check the ball joints. they aren't load acrrying on the style suspension, but they do wear out and will knock like crazy.
