Reset Change Oil Light
Old 04-08-08, 10:57 AM
I have a 2004 Canyon Pick up.....changed the oil, how do I reset the change oil light??
Old 04-08-08, 11:37 AM
zachh1020's Avatar
Turn the key to "On" (Do Not Start It) Push the gas pedal to the floor 3 times within 5 seconds. The light should then flash and reset.
Old 04-09-08, 07:31 AM
I gave it a try ......didnt work anymore ideas?
Old 04-09-08, 07:37 AM
carguyinva's Avatar
does it have a DIC? (driver information center) if so, it's different.
if it doesn't have one, then the aforementioned procedure is correct...
WITHOUT DRIVER INFORMATION CENTER (DIC)
With the ignition key in "ON" but the engine off, fully push and release the accelerator pedal slowly three times within five seconds.
Turn the key to "OFF".
If the "CHANGE ENGINE OIL" message come back on, the engine oil life monitor has not reset. Repeat the procedure
Old 04-09-08, 06:47 PM
20yeartec's Avatar
1: Display engine oil life on the info center
2:Press and hold the select button .oil life will reset to 100%
3:Turn the key off.If the change/oil light comes back on oil life system has not been reset .repeat procedure.
