2002 caliver
Old 04-10-08, 03:45 PM
E
2002 caliver
hi i have this noise coming from rear left wheel area went you hit a bump on the road, i check the exhaust it ok , the car has 85,000 km on it , any ideal mike
Old 04-10-08, 03:57 PM
HotxxxxxxxOKC's Avatar
Sounds like a blown shock.
Old 04-10-08, 07:48 PM
Could be just the mount also. Only way to tell for sure is to visually inspect it once removed from the car. On these cars, you can remove the mount and spring without a spring compressor, but I don't recommend you try it if you have never done it before. Might be better off taking it in to the shop for inspection.
Old 04-11-08, 02:24 AM
diyplank's Avatar
Received 3 Upvotes on 2 Posts
Exactly what Mr. Dummas said!!! HA HA I have a lot of experience w/ cavaliers and when you hit a big pot hole w/ your rear tires it will make a sound b/c the shock so to speak just sets back there w/ little support. So it bangs around that is your noise. If you want have it checked out by a friend or garage to be safe but that is probably what it is.
Old 04-11-08, 07:58 PM
E
2002calivier
hi do these car have mount problem, can you take the shock out without spring compress
Old 04-12-08, 10:34 AM
Yes, it is a known problem. I seperate the spring from the shocks all the time without a compressor, but I don't recommend you do it for safety reasons.
Old 04-12-08, 04:08 PM
20yeartec's Avatar
Stabilizer bar end link? Replace them all the time,small bar going from strut to stabilizer bar.
Old 04-12-08, 07:53 PM
E
2002caliver rear left noise
are you talking about the frontof car, the noise is comeing from left rear
Old 04-13-08, 06:54 PM
20yeartec's Avatar
Sorry i was tired [my bad]
