1999 buick century
Old 04-17-08, 11:22 AM
1999 buick century
I have a 99 Buick Century and the only fan control that works is the highest setting...it doesnt work on low or mid way only high..what is the problem?
Old 04-17-08, 12:53 PM
Unclediezel's Avatar
Blower resistor........
Old 04-17-08, 05:45 PM
ukrkoz's Avatar
means you will need to pull control assy out and replace it. junkyard item, they usually warrent those parts for time long enough to have it installed and checked out. varies from place to place. climate control assembly. they are pricy to buy new. should be easy to remove though. local library/chilton for instructions.
Old 04-17-08, 09:09 PM
The blower motor resistor is not part of the control head. The blower motor resistor is located above the passenger side floor, below the dash. It will be between the blower motor and the firewall. 3 7/32 headed screws secure it into place.
