2004 Saturn Brake Light
Received 0 Votes
A friend came by with his 2004 Saturn to see if I could help him find out why his left brake light does not work.
The right brake light works ok. The same filament in the lamp is used for the rear turn signal and works ok when the left turn signal is on. Lamp out of the car works ok (both filaments).
Does the stop switch have independent contacts for left and right? Is the problem in the turn signal switch? Absent any wiring diagrams I could not help him much.
Also...ensure your checking with the key turned on......
brake lights should work key in or not, at least any car i had so far does so. just checked, positive for mitsubishi and chevy.
no, there's no such thing as seperate left and right brake lights, 'ts not turn light.
do simple: pull the working side bulb out and try it in the non-working plug. if it works ok, then it's light bulb. while you on it, before you install new bulbs, lube connectionss with electrician grease.
there's only one brakes fuse, so you have that one ruled out. new brake bulbs are like 6 bucks a pair. take bad one with you so that they'll match it.
On the Chevy you mentioned......Just a small experiment....
With the key in your hand, Turn on the left signal....nothing happens..... With the key still in your hand and the left turn signal still engaged, step on the brake....The left BRAKE light doesnt work ..??????
There are no left and right Brake lamps, BUT...On cars that share the HI filament for turn and stop..The turn signal switch must disable brake lights on one side or the other, for the turn signal to "Flash" with the brakes applied.
