01 chevy venture
Old 04-19-08, 07:16 PM
R
01 chevy venture
There is no washer fluid coming out of rear wiper. The front is fine. Is there anyone that might have a suggestion?
Old 04-19-08, 07:27 PM
Hi,
The first thing that I would do, is check the hose for any type of blockage, then I would check to see if there was a separate pump that might not be working. If the pump isn't working check fuses and electrical connections at the pump. If electrical checks out replace the pump.
Sorry this is so general, but hopefully it will give you a few ideas.
good luck
Jon
Old 04-19-08, 08:08 PM
Speedwrench's Avatar
don't know for sure but doesn't it have a separate Reservoir for the rear wiper? our astro does. if so is there any fluid in it? If there is fluid check and see if the pump runs with your switch.
life begins when the kids leave home and the dog dies
Old 04-20-08, 06:22 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
In addition to the other suggestions, take a very fine needle and poke the nozzle. Sometimes they get clogged with crud.
