'94 Topaz window?
Old 04-23-08, 06:41 AM
E
'94 Topaz window?
Hey everyone.
The drivers power window on my '94 Topaz has stopped working, recently. When I press the switch I can hear the motor running, and if I push the window down, while pressing down on the switch it will move. Conversely, if I push it up while pressing the switch up, it will go up.
I took of the door panel yesterday to fix the door latch, but didn't really get into looking at the window mechanism.
Any ideas are appreciated.
Thanks in advance,
Mike
Old 04-23-08, 10:40 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Sounds as if the motor may be worn out. Replacement is DIY-able, but it's an intermediate-level DIY job.
Old 04-23-08, 03:55 PM
W
Oh memory don't fail me now!!!!
If I remember right, you'll need to vice grip the regulator to keep it from shearing your fingers.........From there remove the motor, (one bolt will require drilling a hole in the door.........You'll see where the "dimple" is)
Once the motor is out you'll be able to remove the nylon gear that has disintegrated and go from there
Last edited by wrench47; 04-23-08 at 06:32 PM. Reason: Can't spell/can't type/can't see
Old 04-23-08, 04:33 PM
E
Thanks for the replies, guys.
I'll give it a look tomorrow if I get a chance. Doesn't sound too hard.
Thanks again,
Mike
Old 04-23-08, 04:37 PM
Unclediezel's Avatar
Ditto......
I seem, to remember a cable driven regulator on these cars, but I may be drastically wrong.....
Either way, disassembly and inspection is recommended.
What bothers me here is Motors very rarely "Fail" on these cars. As mentioned, a "Nylon Gearpack" was usually wiped out. However, the gear would shred internally, and not allow you free movement of the window.......
Just food for thought....
Old 05-06-08, 11:39 AM
E
Hey, sorry for the late reply.
I removed the door panel and attempted to remove the motor for the window and- gave up quite quickly.
The motor is situated in a pretty tricky spot and after messing around fixing the door latch in same door- I was too agitated to continue working in such a chore of a place.
I appreciate the replys and advice, and when I get my Sawzall battery charged up I'll let you know how it goes!
Just kidding- I'm not going to by cutting hte door up just for that. But I was tempted.
Thanks again,
Mike
Old 05-06-08, 02:14 PM
All jokes aside.......If you look carefully at the door skin, with the upholstery panel removed. You will see 3 little "Dings" or dimples...in a Triangular formation around the perimeter of where the motor is.....using a 1/2 inch hole saw, drill out the dimples.....and you now have access to the motor mounting bolts.......
Old 05-06-08, 03:19 PM
mikeTN's Avatar
Received 1 Upvote on 1 Post
Unhappy
i THINK that regulator has a cable lift mechanism with plastic fixtures to hold it to the regulator. the plastic fatigues and breaks. the motor usually lasts a long time. i HAVE gotten the regulator in the correct position and applied a devse before and after the plastic clamp and mad it work for a while. i have replaced ALL FOUR regulators in my caddy.(factory defect!?). good luck.
