wheel stud
Old 04-28-08, 05:11 PM
wheel stud
Hi there I need help replacing a wheel stud on a 99 oldsmobile intriguie Can I do it with out removing the rotors or wheel hub please help.
Old 04-28-08, 05:22 PM
Unclediezel's Avatar
Rotors definitely must be removed...The hub is a maybe...
DONT CUT IT, to take it out...if you can get it out of the hub flange the new one will go back in the same way.
Old 04-28-08, 05:23 PM
HotxxxxxxxOKC's Avatar
You are most likely going to have to remove the outer bearing and rotor.
This is not a hard task, why don't you want to remove these?
