1997 Jeep Grand Cherokee Limited Transmisson Problems
Old 04-30-08, 02:19 AM
Angry 1997 Jeep Grand Cherokee Limited Transmisson Problems
I Put The 4x4 In And It Shows Check 4 Wheel Drve Switch Could Someone Tell Me What Switch That Is Thanks
Old 04-30-08, 04:38 AM
carguyinva's Avatar
the only switch that i see in the system is the 4WD select switch which is mounted on the transfer case shift lever.
Old 05-06-08, 10:05 PM
1997 jeep grand cherokee 4x4 service switch
Originally Posted by warddawg View Post
I Put The 4x4 In And It Shows SERVICE 4 Wheel Drive Switch Could Someone Tell Me What Switch That Is Thanks
thanks for the help but theres llike three switches, one is on the back of the transfer case by the drive shaft the other 2 or on top of the transmission itself would it be the one by the drive shaft
Old 05-07-08, 08:53 AM
carguyinva's Avatar
i'm thinking that the one by the driveshaft is probably the speed sensor. the text description is on the transfer case shift lever...do you have to shift the TC manually to select 4WD? if so, could it be under the trim inside the vehicle where the lever is?
Old 05-09-08, 02:55 AM
Thumbs up warddawg
thanks, i just got your message i will check it out and let you no what i find, appreciate all your help carguyinva
Old 05-17-08, 08:01 PM
Cool
i went to oreilys parts store they told me there where 2 4x4 switches is there 1 or 2what do you think 1 or 2
