no blinky
Old 05-10-08, 06:29 PM
Thanks I only added my post under the one because it was the same year/make of the car I have.
It is an 88 Chevy Corsica The blinkers come on, but they do not pulsate in the front or back of the car. The fuse seems to be good, what would be the cause of this problem?
Last edited by Meditrina; 05-10-08 at 06:45 PM. Reason: created a new post...more people will see it this way.
Old 05-10-08, 06:34 PM
carguyinva's Avatar
Hi...welcome to the forum. I moved your post so more folks would see it. I also edited out the quotes. Could you add a little more information, please? What make, model and year and anything you've tried to resolve the problem. thanks...
Old 05-10-08, 09:37 PM
Speedwrench's Avatar
if the lights come on but do not blink, check the flasher unit. if that does not remedy the problem then start checking grounds for the lights. some times if you don't have a good enough ground the flasher will not energize properly.
carguy they said 88 corsica. you must be on autopilot.
life begins when the kids leave home and the dog dies.
Old 05-11-08, 08:54 PM
carguyinva's Avatar
speedy...the original post didn't say that. it was a reply to another post and had no info. the OP edited after i asked foryear, make and model
Old 05-12-08, 02:52 AM
question
do your flashers work? turn on the flashers and walk around the car and verify that all bulbs are flashing like they should.
Trackbacks are On
Pingbacks are On
Refbacks are On
