I think rear strut is broke.....
Old 05-16-08, 04:11 PM
G
Have a 96 Dodge Neon. Jacked up the right rear of the car to change a tire and noticed that the top of the strut or shock isn't connected to the top mounting piece of the car. Is this suppose to do this?
Old 05-16-08, 04:54 PM
Unclediezel's Avatar
No.......
Check carefully...you have one of two possibilities.....
1--The strut mount is broken and will need to be replaced...or....
2- The body of the car has rotted thru and no longer holds the strut mount....
The latter.... depending on how much metal is gone...it may be possible to weld in a new "TOWER PLATE".
Either way...ASAP... have it repaired. The strut could concievably punch its way into the passenger compartment under a severe enough "BUMP".
Old 05-17-08, 12:14 AM
G
The strut mount is still solid in the trunk of the car. Pulled off the rubber cap on top of the strut mount and there was nothing under there. I don't even know what the top of the shock was connected to.
Old 08-15-08, 01:40 AM
did you find the problem yet? i'm having a similar problem.
