Wheel bearing nightmare
Received 0 Votes
Ok, hopefully someone can help with this.
Replacing a real wheel bearing on a Porsche 968. Lots of good info on the net and in the shop manual, easy, right? I get everything apart except the hub and bearing. When I follow the net instructions, half the bearing comes out with the hub (easily removed later).
The problem is, this is a sealed bearing. While following the procedure (heating the trailing arm, using a slide hammer and such), the rest of the bearing insides comes out. A near perfect round (hard to get a grip on with slide hammer) I believe it is called the race, but I will call it the bearing case is inside the trailing arm (this bearing was shot). Any suggestions on how to get it out? I would cut it (would I need a carbide blade? It is a hardened case), but I do not want to damage the trailing arm.
Help!
Help!
You could cut the race with a carbide type bit. I have had to do this before. What I do is grind or cut it in at least 2 places, very carefully not to cut into whatever it is pressed into. Then take a chisel and give it a few whacks and it should break where you cut it and it will be much easier to remove. If you have already tried to remove it with a slide hammer and some type of remover then it may be too tight to remove this way and cutting it may be your best bet.
Hope this helps ya,
Billy
Hope this helps ya,
Billy
